MicroChip code examples help
scottlad
Newbie level 5
Newbie level 5
I;m looking at using the ''CE018 - Using the Fast Fourier Transform (FFT) for Frequency Detection'' example program from MicroChips website. I spent the last few days brushing up on my knowledge of Fourier Series and the DFT. I'm following on from my program which I got some help with here which was a frequency counter.
Normally I write my on programs in Notepad ++ and run a compiler. I added the gld, fft header file and inc file to the appropriate folders. I'll admit I'm a bit out of my depth but I'll keep at it, I added the three source codes to the same 'main.c' file and I tried to compile it. The readme file provided by microchip didn't match up very well with the actual folders downloaded. I'm not quite sure about the x and y data space. My plan is to replace the input array declared in the Y data space with an input signal to an A/d channel.
#include <p30F4011.h>
#include <dsp.h>
#include <fft.h>
/* Device configuration register macros for building the hex file */
_FOSC(CSW_FSCM_OFF & FRC_PLL16); // Fosc=16x7.5MHz, Fcy=30MHz
_FWDT(WDT_OFF);                         /* Watchdog timer disabled */
_FBORPOR(PBOR_OFF & MCLR_EN);           /* Brown-out reset disabled, MCLR reset enabled */
_FGS(CODE_PROT_OFF);                    /* Code protect disabled */
/* Extern definitions */
extern fractcomplex sigCmpx[FFT_BLOCK_LENGTH] 		/* Typically, the input signal to an FFT  */
__attribute__ ((section (".ydata, data, ymemory"), 	/* routine is a complex array containing samples */
aligned (FFT_BLOCK_LENGTH * 2 *2)));      		/* of an input signal. For this example, */
							/* we will provide the input signal in an */
							/* array declared in Y-data space. */
/* Global Definitions */
#ifndef FFTTWIDCOEFFS_IN_PROGMEM
fractcomplex twiddleFactors[FFT_BLOCK_LENGTH/2] 	/* Declare Twiddle Factor array in X-space*/
__attribute__ ((section (".xbss, bss, xmemory"), aligned (FFT_BLOCK_LENGTH*2)));
#else
extern const fractcomplex twiddleFactors[FFT_BLOCK_LENGTH/2]	/* Twiddle Factor array in Program memory */
__attribute__ ((space(auto_psv), aligned (FFT_BLOCK_LENGTH*2)));
#endif
int	peakFrequencyBin = 0;				/* Declare post-FFT variables to compute the */
unsigned long peakFrequency = 0;			/* frequency of the largest spectral component */
int main(void)
	int i = 0;
	fractional *p_real = &sigCmpx[0].real ;
	fractcomplex *p_cmpx = &sigCmpx[0] ;
#ifndef FFTTWIDCOEFFS_IN_PROGMEM					/* Generate TwiddleFactor Coefficients */
	TwidFactorInit (LOG2_BLOCK_LENGTH, &twiddleFactors[0], 0);	/* We need to do this only once at start-up */
#endif
	for ( i = 0; i < FFT_BLOCK_LENGTH; i++ )/* The FFT function requires input data */
	{					/* to be in the fractional fixed-point range [-0.5, +0.5]*/
		*p_real = *p_real >>1 ;		/* So, we shift all data samples by 1 bit to the right. */
		*p_real++;			/* Should you desire to optimize this process, perform */
	}					/* data scaling when first obtaining the time samples */
						/* Or within the BitReverseComplex function source code */
	p_real = &sigCmpx[(FFT_BLOCK_LENGTH/2)-1].real ;	/* Set up pointers to convert real array */
	p_cmpx = &sigCmpx[FFT_BLOCK_LENGTH-1] ; /* to a complex array. The input array initially has all */
						/* the real input samples followed by a series of zeros */
	for ( i = FFT_BLOCK_LENGTH; i > 0; i-- ) /* Convert the Real input sample array */
	{					/* to a Complex input sample array  */
		(*p_cmpx).real = (*p_real--);	/* We will simpy zero out the imaginary  */
		(*p_cmpx--).imag = 0x0000;	/* part of each data sample */
	/* Perform FFT operation */
	FFTComplexIP (LOG2_BLOCK_LENGTH, &sigCmpx[0], &twiddleFactors[0], COEFFS_IN_DATA);
#else
	FFTComplexIP (LOG2_BLOCK_LENGTH, &sigCmpx[0], (fractcomplex *) __builtin_psvoffset(&twiddleFactors[0]), (int) __builtin_psvpage(&twiddleFactors[0]));
#endif
	// Store output samples in bit-reversed order of their addresses
	BitReverseComplex (LOG2_BLOCK_LENGTH, &sigCmpx[0]);
	// Compute the square magnitude of the complex FFT output array so we have a Real output vetor
	SquareMagnitudeCplx(FFT_BLOCK_LENGTH, &sigCmpx[0], &sigCmpx[0].real);
	/* Find the frequency Bin ( = index into the SigCmpx[] array) that has the largest energy*/
	/* i.e., the largest spectral component */
	VectorMax(FFT_BLOCK_LENGTH/2, &sigCmpx[0].real, &peakFrequencyBin);
	/* Compute the frequency (in Hz) of the largest spectral component */
	peakFrequency = peakFrequencyBin*(SAMPLING_RATE/FFT_BLOCK_LENGTH);
        while (1);	/* Place a breakpoint here and observe the watch window variables */
#ifdef FFTTWIDCOEFFS_IN_PROGMEM
#if (FFT_BLOCK_LENGTH == 64)
        const fractcomplex twiddleFactors[] __attribute__ ((space(auto_psv), aligned (FFT_BLOCK_LENGTH*2)))=
        0x7FFF, 0x0000, 0x7F62, 0xF374, 0x7D8A, 0xE707, 0x7A7D, 0xDAD8,
        0x7642, 0xCF04, 0x70E3, 0xC3A9, 0x6A6E, 0xB8E3, 0x62F2, 0xAECC,
        0x5A82, 0xA57E, 0x5134, 0x9D0E, 0x471D, 0x9592, 0x3C57, 0x8F1D,
        0x30FC, 0x89BE, 0x2528, 0x8583, 0x18F9, 0x8276, 0x0C8C, 0x809E,
        0x0000, 0x8000, 0xF374, 0x809E, 0xE707, 0x8276, 0xDAD8, 0x8583,
        0xCF04, 0x89BE, 0xC3A9, 0x8F1D, 0xB8E3, 0x9592, 0xAECC, 0x9D0E,
        0xA57D, 0xA57D, 0x9D0E, 0xAECC, 0x9592, 0xB8E3, 0x8F1D, 0xC3A9,
        0x89BE, 0xCF04, 0x8583, 0xDAD8, 0x8276, 0xE707, 0x809E, 0xF374
#endif
#if (FFT_BLOCK_LENGTH == 128)
        0x7FFF, 0x0000, 0x7FD9, 0xF9B8, 0x7F62, 0xF374, 0x7E9D, 0xED38,
        0x7D8A, 0xE707, 0x7C2A, 0xE0E6, 0x7A7D, 0xDAD8, 0x7885, 0xD4E1,
        0x7642, 0xCF04, 0x73B6, 0xC946, 0x70E3, 0xC3A9, 0x6DCA, 0xBE32,
        0x6A6E, 0xB8E3, 0x66D0, 0xB3C0, 0x62F2, 0xAECC, 0x5ED7, 0xAA0A,
        0x5A82, 0xA57E, 0x55F6, 0xA129, 0x5134, 0x9D0E, 0x4C40, 0x9930,
        0x471D, 0x9592, 0x41CE, 0x9236, 0x3C57, 0x8F1D, 0x36BA, 0x8C4A,
        0x30FC, 0x89BE, 0x2B1F, 0x877B, 0x2528, 0x8583, 0x1F1A, 0x83D6,
        0x18F9, 0x8276, 0x12C8, 0x8163, 0x0C8C, 0x809E, 0x0648, 0x8027,
        0x0000, 0x8000, 0xF9B8, 0x8027, 0xF374, 0x809E, 0xED38, 0x8163,
        0xE707, 0x8276, 0xE0E6, 0x83D6, 0xDAD8, 0x8583, 0xD4E1, 0x877C,
        0xCF04, 0x89BE, 0xC946, 0x8C4A, 0xC3A9, 0x8F1D, 0xBE32, 0x9236,
        0xB8E3, 0x9592, 0xB3C0, 0x9931, 0xAECC, 0x9D0E, 0xAA0A, 0xA129,
        0xA57E, 0xA57E, 0xA129, 0xAA0A, 0x9D0E, 0xAECC, 0x9931, 0xB3C0,
        0x9592, 0xB8E3, 0x9236, 0xBE32, 0x8F1D, 0xC3A9, 0x8C4A, 0xC946,
        0x89BE, 0xCF04, 0x877C, 0xD4E1, 0x8583, 0xDAD8, 0x83D6, 0xE0E6,
        0x8276, 0xE707, 0x8163, 0xED38, 0x809E, 0xF374, 0x8027, 0xF9B8
#endif
#if (FFT_BLOCK_LENGTH == 256)
        const fractcomplex twiddleFactors[] __attribute__ ((space(auto_psv), aligned (FFT_BLOCK_LENGTH*2))) =
        0x7FFF, 0x0000, 0x7FF6, 0xFCDC, 0x7FD9, 0xF9B8, 0x7FA7, 0xF695,
        0x7F62, 0xF374, 0x7F0A, 0xF055, 0x7E9D, 0xED38, 0x7E1E, 0xEA1E,
        0x7D8A, 0xE707, 0x7CE4, 0xE3F4, 0x7C2A, 0xE0E6, 0x7B5D, 0xDDDC,
        0x7A7D, 0xDAD8, 0x798A, 0xD7D9, 0x7884, 0xD4E1, 0x776C, 0xD1EF,
        0x7642, 0xCF04, 0x7505, 0xCC21, 0x73B6, 0xC946, 0x7255, 0xC673,
        0x70E3, 0xC3A9, 0x6F5F, 0xC0E9, 0x6DCA, 0xBE32, 0x6C24, 0xBB85,
        0x6A6E, 0xB8E3, 0x68A7, 0xB64C, 0x66CF, 0xB3C0, 0x64E8, 0xB140,
        0x62F2, 0xAECC, 0x60EC, 0xAC65, 0x5ED7, 0xAA0A, 0x5CB4, 0xA7BD,
        0x5A82, 0xA57E, 0x5843, 0xA34C, 0x55F6, 0xA129, 0x539B, 0x9F14,
        0x5134, 0x9D0E, 0x4EC0, 0x9B18, 0x4C40, 0x9931, 0x49B4, 0x9759,
        0x471D, 0x9592, 0x447B, 0x93DC, 0x41CE, 0x9236, 0x3F17, 0x90A1,
        0x3C57, 0x8F1D, 0x398D, 0x8DAB, 0x36BA, 0x8C4A, 0x33DF, 0x8AFB,
        0x30FC, 0x89BE, 0x2E11, 0x8894, 0x2B1F, 0x877C, 0x2827, 0x8676,
        0x2528, 0x8583, 0x2224, 0x84A3, 0x1F1A, 0x83D6, 0x1C0B, 0x831C,
        0x18F9, 0x8276, 0x15E2, 0x81E3, 0x12C8, 0x8163, 0x0FAB, 0x80F7,
        0x0C8C, 0x809E, 0x096B, 0x8059, 0x0648, 0x8028, 0x0324, 0x800A,
        0x0000, 0x8000, 0xFCDC, 0x800A, 0xF9B8, 0x8028, 0xF695, 0x8059,
        0xF374, 0x809E, 0xF055, 0x80F7, 0xED38, 0x8163, 0xEA1E, 0x81E3,
        0xE707, 0x8276, 0xE3F5, 0x831C, 0xE0E6, 0x83D6, 0xDDDC, 0x84A3,
        0xDAD8, 0x8583, 0xD7D9, 0x8676, 0xD4E1, 0x877C, 0xD1EF, 0x8894,
        0xCF04, 0x89BE, 0xCC21, 0x8AFB, 0xC946, 0x8C4A, 0xC673, 0x8DAB,
        0xC3A9, 0x8F1D, 0xC0E9, 0x90A1, 0xBE32, 0x9236, 0xBB85, 0x93DC,
        0xB8E3, 0x9593, 0xB64C, 0x975A, 0xB3C0, 0x9931, 0xB140, 0x9B18,
        0xAECC, 0x9D0E, 0xAC65, 0x9F14, 0xAA0A, 0xA129, 0xA7BD, 0xA34C,
        0xA57E, 0xA57E, 0xA34C, 0xA7BD, 0xA129, 0xAA0A, 0x9F14, 0xAC65,
        0x9D0E, 0xAECC, 0x9B18, 0xB140, 0x9931, 0xB3C0, 0x975A, 0xB64C,
        0x9593, 0xB8E3, 0x93DC, 0xBB85, 0x9236, 0xBE32, 0x90A1, 0xC0E9,
        0x8F1D, 0xC3A9, 0x8DAB, 0xC673, 0x8C4A, 0xC946, 0x8AFB, 0xCC21,
        0x89BF, 0xCF04, 0x8894, 0xD1EF, 0x877C, 0xD4E1, 0x8676, 0xD7D9,
        0x8583, 0xDAD8, 0x84A3, 0xDDDC, 0x83D6, 0xE0E6, 0x831C, 0xE3F5,
        0x8276, 0xE707, 0x81E3, 0xEA1E, 0x8163, 0xED38, 0x80F7, 0xF055,
        0x809E, 0xF374, 0x8059, 0xF695, 0x8028, 0xF9B8, 0x800A, 0xFCDC
#endif
#if (FFT_BLOCK_LENGTH == 512 )
        const fractcomplex twiddleFactors[] __attribute__ ((space(auto_psv), aligned (FFT_BLOCK_LENGTH*2*2))) =
        0x7FFF, 0x0000, 0x7FFE, 0xFE6E, 0x7FF6, 0xFCDC, 0x7FEA, 0xFB4A,
        0x7FD9, 0xF9B8, 0x7FC2, 0xF827, 0x7FA7, 0xF695, 0x7F87, 0xF505,
        0x7F62, 0xF374, 0x7F38, 0xF1E4, 0x7F0A, 0xF055, 0x7ED6, 0xEEC6,
        0x7E9D, 0xED38, 0x7E60, 0xEBAB, 0x7E1E, 0xEA1E, 0x7DD6, 0xE892,
        0x7D8A, 0xE707, 0x7D3A, 0xE57D, 0x7CE4, 0xE3F4, 0x7C89, 0xE26D,
        0x7C2A, 0xE0E6, 0x7BC6, 0xDF61, 0x7B5D, 0xDDDC, 0x7AEF, 0xDC59,
        0x7A7D, 0xDAD8, 0x7A06, 0xD958, 0x798A, 0xD7D9, 0x790A, 0xD65C,
        0x7885, 0xD4E1, 0x77FB, 0xD367, 0x776C, 0xD1EF, 0x76D9, 0xD079,
        0x7642, 0xCF04, 0x75A6, 0xCD92, 0x7505, 0xCC21, 0x7460, 0xCAB2,
        0x73B6, 0xC946, 0x7308, 0xC7DB, 0x7255, 0xC673, 0x719E, 0xC50D,
        0x70E3, 0xC3A9, 0x7023, 0xC248, 0x6F5F, 0xC0E9, 0x6E97, 0xBF8C,
        0x6DCA, 0xBE32, 0x6CF9, 0xBCDA, 0x6C24, 0xBB85, 0x6B4B, 0xBA33,
        0x6A6E, 0xB8E3, 0x698C, 0xB796, 0x68A7, 0xB64C, 0x67BD, 0xB505,
        0x66D0, 0xB3C0, 0x65DE, 0xB27F, 0x64E9, 0xB140, 0x63EF, 0xB005,
        0x62F2, 0xAECC, 0x61F1, 0xAD97, 0x60EC, 0xAC65, 0x5FE4, 0xAB36,
        0x5ED8, 0xAA0A, 0x5DC8, 0xA8E2, 0x5CB4, 0xA7BD, 0x5B9D, 0xA69C,
        0x5A83, 0xA57E, 0x5964, 0xA463, 0x5843, 0xA34C, 0x571E, 0xA238,
        0x55F6, 0xA128, 0x54CA, 0xA01C, 0x539B, 0x9F14, 0x5269, 0x9E0F,
        0x5134, 0x9D0E, 0x4FFB, 0x9C11, 0x4EC0, 0x9B17, 0x4D81, 0x9A22,
        0x4C40, 0x9930, 0x4AFB, 0x9843, 0x49B4, 0x9759, 0x486A, 0x9674,
        0x471D, 0x9592, 0x45CD, 0x94B5, 0x447B, 0x93DC, 0x4326, 0x9307,
        0x41CE, 0x9236, 0x4074, 0x9169, 0x3F17, 0x90A1, 0x3DB8, 0x8FDD,
        0x3C57, 0x8F1D, 0x3AF3, 0x8E62, 0x398D, 0x8DAB, 0x3825, 0x8CF8,
        0x36BA, 0x8C4A, 0x354E, 0x8BA0, 0x33DF, 0x8AFB, 0x326E, 0x8A5A,
        0x30FC, 0x89BE, 0x2F87, 0x8927, 0x2E11, 0x8894, 0x2C99, 0x8805,
        0x2B1F, 0x877B, 0x29A4, 0x86F6, 0x2827, 0x8676, 0x26A8, 0x85FA,
        0x2528, 0x8583, 0x23A7, 0x8511, 0x2224, 0x84A3, 0x209F, 0x843A,
        0x1F1A, 0x83D6, 0x1D93, 0x8377, 0x1C0C, 0x831C, 0x1A83, 0x82C6,
        0x18F9, 0x8276, 0x176E, 0x822A, 0x15E2, 0x81E2, 0x1455, 0x81A0,
        0x12C8, 0x8163, 0x113A, 0x812A, 0x0FAB, 0x80F6, 0x0E1C, 0x80C8,
        0x0C8C, 0x809E, 0x0AFB, 0x8079, 0x096B, 0x8059, 0x07D9, 0x803E,
        0x0648, 0x8027, 0x04B6, 0x8016, 0x0324, 0x800A, 0x0192, 0x8002,
        0x0000, 0x8000, 0xFE6E, 0x8002, 0xFCDC, 0x800A, 0xFB4A, 0x8016,
        0xF9B8, 0x8027, 0xF827, 0x803E, 0xF695, 0x8059, 0xF505, 0x8079,
        0xF374, 0x809E, 0xF1E4, 0x80C8, 0xF055, 0x80F6, 0xEEC6, 0x812A,
        0xED38, 0x8163, 0xEBAB, 0x81A0, 0xEA1E, 0x81E2, 0xE892, 0x822A,
        0xE707, 0x8276, 0xE57D, 0x82C6, 0xE3F4, 0x831C, 0xE26D, 0x8377,
        0xE0E6, 0x83D6, 0xDF61, 0x843A, 0xDDDC, 0x84A3, 0xDC59, 0x8511,
        0xDAD8, 0x8583, 0xD958, 0x85FA, 0xD7D9, 0x8676, 0xD65C, 0x86F6,
        0xD4E1, 0x877B, 0xD367, 0x8805, 0xD1EF, 0x8894, 0xD079, 0x8927,
        0xCF04, 0x89BE, 0xCD92, 0x8A5A, 0xCC21, 0x8AFB, 0xCAB2, 0x8BA0,
        0xC946, 0x8C4A, 0xC7DB, 0x8CF8, 0xC673, 0x8DAB, 0xC50D, 0x8E62,
        0xC3A9, 0x8F1D, 0xC248, 0x8FDD, 0xC0E9, 0x90A1, 0xBF8C, 0x9169,
        0xBE32, 0x9236, 0xBCDA, 0x9307, 0xBB85, 0x93DC, 0xBA33, 0x94B5,
        0xB8E3, 0x9592, 0xB796, 0x9674, 0xB64C, 0x9759, 0xB505, 0x9843,
        0xB3C0, 0x9930, 0xB27F, 0x9A22, 0xB140, 0x9B17, 0xB005, 0x9C11,
        0xAECC, 0x9D0E, 0xAD97, 0x9E0F, 0xAC65, 0x9F14, 0xAB36, 0xA01C,
        0xAA0A, 0xA128, 0xA8E2, 0xA238, 0xA7BD, 0xA34C, 0xA69C, 0xA463,
        0xA57D, 0xA57D, 0xA463, 0xA69C, 0xA34C, 0xA7BD, 0xA238, 0xA8E2,
        0xA128, 0xAA0A, 0xA01C, 0xAB36, 0x9F14, 0xAC65, 0x9E0F, 0xAD97,
        0x9D0E, 0xAECC, 0x9C11, 0xB005, 0x9B17, 0xB140, 0x9A22, 0xB27F,
        0x9930, 0xB3C0, 0x9843, 0xB504, 0x9759, 0xB64C, 0x9674, 0xB796,
        0x9592, 0xB8E3, 0x94B5, 0xBA33, 0x93DC, 0xBB85, 0x9307, 0xBCDA,
        0x9236, 0xBE32, 0x9169, 0xBF8C, 0x90A1, 0xC0E9, 0x8FDD, 0xC248,
        0x8F1D, 0xC3A9, 0x8E62, 0xC50D, 0x8DAB, 0xC673, 0x8CF8, 0xC7DB,
        0x8C4A, 0xC946, 0x8BA0, 0xCAB2, 0x8AFB, 0xCC21, 0x8A5A, 0xCD92,
        0x89BE, 0xCF04, 0x8927, 0xD079, 0x8894, 0xD1EF, 0x8805, 0xD367,
        0x877B, 0xD4E1, 0x86F6, 0xD65C, 0x8676, 0xD7D9, 0x85FA, 0xD958,
        0x8583, 0xDAD8, 0x8510, 0xDC59, 0x84A3, 0xDDDC, 0x843A, 0xDF61,
        0x83D6, 0xE0E6, 0x8377, 0xE26D, 0x831C, 0xE3F4, 0x82C6, 0xE57D,
        0x8275, 0xE707, 0x8229, 0xE892, 0x81E2, 0xEA1E, 0x81A0, 0xEBAB,
        0x8163, 0xED38, 0x812A, 0xEEC6, 0x80F6, 0xF055, 0x80C8, 0xF1E4,
        0x809E, 0xF374, 0x8079, 0xF505, 0x8059, 0xF695, 0x803E, 0xF827,
        0x8027, 0xF9B8, 0x8016, 0xFB4A, 0x800A, 0xFCDC, 0x8002, 0xFE6E
#endif
#endif
fractcomplex sigCmpx[FFT_BLOCK_LENGTH] __attribute__ ((section (".ydata, data, ymemory"), aligned (FFT_BLOCK_LENGTH * 2 *2))) =
0x7FFF, 0x7FFF, 0x7FFF, 0x7FFF, 0x7FFF,
0x8001, 0x8001, 0x8001, 0x8001, 0x8001,
0x7FFF, 0x7FFF, 0x7FFF, 0x7FFF, 0x7FFF, 0x8001,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
Edit I found a good explanation of the X and Y data here
HTML:
http://www.mikroe.com/chapters/view/41/chapter-8-memory-model/
. Just have to figure out how to compile the program now.
