[PIC] MicroC USB library Example shows problem.
chandresha1
Member level 2
Member level 2
Bremen, Germany
Hello,
I am newbie in USB PIC programming. I am simple trying USB example given in MicroC USB library. I can easily "Build" this example. But whenever i try to "Start Debugger" it shows some application Error. I have also included descriptor file in my project.
Would you please show the code you are trying to build.. And Exactly what's the error code you are being viewed by MikroC...!
Would you please show the code you are trying to build. And Exactly what's the error code you are being viewed by MikroC?
Actually i wanted to make DAQ board for labview by using PIC18f4550 through USB communication. so just for beginning i want to simulate USB communication in proteus. Here is my code.(From USB library)
Crystal freq=12Mhz
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
unsigned char readbuff[64] absolute 0x500;   // Buffers should be in USB RAM, please consult datasheet
unsigned char writebuff[64] absolute 0x540;
char cnt;
char kk;
void interrupt(){
   USB_Interrupt_Proc();                   // USB servicing is done inside the interrupt
void main(void){
  ADCON1 |= 0x0F;                         // Configure all ports with analog function as digital
  CMCON  |= 7;                            // Disable comparators
  HID_Enable(&readbuff,&writebuff);       // Enable HID communication
  while(1){
    while(!HID_Read());
    for(cnt=0;cnt<64;cnt++)
      writebuff[cnt]=readbuff[cnt];
    while(!HID_Write(&writebuff,64));
I can build it successful. But the moment i press "Start debugging" i got this error.(Attached files)
