meta materials in HFSS
mahima tandon
hello everyone!
i was working on UWB now i want to introduce meta materials to UWB antennas . can anyone help me to do so and explain me how can i do that.........:-(
I can't understand your problem. The metamaterial is a circuit. Just create this circuit inside your project and simulate (and it will take a helluva time and memory)
Or you can try estimating on the single frequency by creating a dielectric with negative ε and negative µ. But it is not correct because metamaterials are highly dispersive, anisotropic, and have complex parameters.
You can create a unit cell with periodic boundaries and apply driven terminal to analyze all the modes in infinite structure. But this way you can analyze only the metamaterial itself.
Actually, there are some hybrid modes in ver.14 and above allowing you to quickly solve periodic unit cells INSIDE non-periodic (antenna) model. But I don't know how to use this. I use ver.13, which does not have that option.
The coolest material for simulation is the air . No loses, no tangent delta, no imaginary part.:???: It is from God?
as i got a reply that metamaterial is a circuit and create this circuit inside the project............
my question is this only how can it be created simply by assigning the radiation box with electric and magnetic properties both
I`m playing with CST.
The air is lossy. Worse, it can be ionized. It can hold water as well. And it is high impedance, hell for impedance matching. From the other hand, the radiation cone is too wide allowing for radiation loss in bent circuits.
In HFSS, there's vacuum for quick simulation purpose.
seems, you are playing drunk...
I don't get, what you want.
You have a circuit for metamaterial. Put it inside the air box (ok, air box made of vacuum). Apply boundaries to the box as you like.
If you want to know full modal profile for infinite structure - apply periodic boundaries to the unit cells in place of junction, use driven terminal solver.
Of course, you can replace 3D models of microstrips with 2D planar figures, where layered impedance boundary is applied. This will save you time with some penalty in precision (note: does not work for coplanar and slotline circuits)
i have a UWB structure which i want to realize through meta materials.............
that i am not able to understand how to make it ......
first of all how to make a split ring resonator in HFSS...........
Ah, I see why we couldn't understand your question.
You don't know how to work in HFSS. So, I recommend you first try to follow basic tutorials to get familiar with the editor. (Autodesk 3D studio/3DMAX experience would be very helpful as well)
It is pointless to ask here questions about metamaterials, while you don't know how to simulate simple resonator.
BTW. There are some tutorials exactly for basic SRR structures can be found at ANSOFT of.site.
And I should poit it, that SRRs are NOT UWB. Of course you can operate in the whole Brillouin zone, but it will have very large refraction index and impedance dispersion in the band. And plasmonic wires are very lossy as well. You should turn to DR based 3D structures.
Hi Mahima,
You can find an example of metamaterial unit cell in this post: https://www.edaboard.com/threads/87180/#post382922. You have to change the inside resonator, and place your SRR resonator. You have to scale the unit cell size to the periodicity you want to have, and chage the solution frequency to your desired one.
Regards,
Pere
Andryusha don`t worry. Only horse in spheric vacuum.8-O
In the library Andryusha they say nothing concerning Th Δ and :shock: ξ=1.00059.
hello everyone!
Hi mahima tandon,
As Andryuha pointed out, realized metamaterials are in general highly dispersive. I wouldn't put them in the UWB category. Before you put them into an antenna, I would recommend that you verify their bandwidth on their own.
Good Luck
Hallo! mahima tandon
i have made like this and inculded it with my UWB antenna if you want to make split ring resonator in hfss , simply you draw circle for example with rauis 5mm and draw another circle with radius 3mm with the same center point and then subtract and then you can add two small rectangular at the spacing you want and subtract again.
the attached file will help you
  • Split ring resonator.rar
