MWO has 2 EM simulators: EMSight and AXIEM. The AXIEM is more powerfull and has very advanced meshing algorithms like edge meshing, using triangles instead of squares and so on. It mostly calculates the best settings for you. You should analyze your antenna with the basis settings first and nex try a denser meshing to see if the results are convergent
It is much simpler to use AXIEM compared to EMSight for Antennas...
If you already have the EMSight setup then simply Select the Simulator as AXIEM (Right Click & select Select Simulator Option)
Or Copy & Paste the EMSight structre& select AXIEM...
Then change some of the Settings for AXIEM to simulate such as uncheck AFS to get Radiation Patterns & CVurrent Annimations...
If you have problems then upload ur MWO file (*.emp) here...Will help you...
AXIEM actually uses both triangle and rectangle in meshing. It seems that it tries to use rectangle as much as possible, which is good for accuary and efficiency.
In AXIEM I uncheck AFS but everytime I try to create radiation pattern graph, I get error:
11:18:35 Measurement - AntennaPC_ETheta(90,1)[*] : Could not create simulator
and yet:
11:12:41 A minimum of 5 frequency points must be requested in order to use AFS. Only 1 points were requested, AFS will not be used.
But AFS unchecked as seen in screenshot, right?
Is this becose of version of MWO (2009), that I can't create radiation pattern in AXIEM solver mode?
Thanks for help.
Yes it is because of the Rlease / Vesrion of the Axiem you are using...in order to plot radiation & antenna analysis using AXIEM you need AWRDE 2010 version 9.05....Then it works fine...
