mesh properties in CST (number of mesh cells)
ravi8331
Full Member level 4
India
hii
plz tell me how can i analyze that how much no. of mesh cell is best for my structure and these mesh setting will provide good result in CST???
plasma
Advanced Member level 2
just check the box of adaptive mesh in the solver window let it run until it will
stops then you will see down in the window the mesh that gives you the best results
it increase the mesh from one run to the second until the error small as it written in
the error box.
ravi8331
Full Member level 4
India
hello sir,
i hv done this but there are r also problem.......i explain here......
firstly i run my program with default mesh setting after that i use adaptive meshing and getting result. then using this adaptive mesh setting i run parametric sweep and getting variation of height of probe with s parameter and by getting proper height value i run my program again for getting all antenna properties.
after finish this procedure i am getting results but if again i run adaptive meshing for checking my results then i again getting different results n i don't understand why these results are different. so plz tell me when i use the adaptive meshing and what is the meshing properties for gud result???
