doors666
Junior Member level 1
- Joined
- Mar 2, 2013
- Messages
- 17
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,427
I have a analog dc signal for which the voltage varies from 0-1.23v. I also have a 3.3v pwm signal, for which the worst case frequency will be 1mhz. I need to merge these two so that the output signal is switched as per the pwm but the voltage level is as per the analog signal, kinda like a switched varying dc signal. Too much of voltage should not be dropped in the process and the fast response time is also important. How do I do this.
