Re: Mentor Graphic: Project Porting to another SoftWare (50p
sadid said:
/.../How can I port my project from FPGA Advantage to qu(at)rtus or ISE?
if I understand your question correctly, you should:
- create your project with so-called black-boxes which are
'place holders' for ise/quartus specific macros;
- add an attributes 'black box' for the modules if your tool requires it
[most probably yes];
- compile to generate an input for ise/quartus place&route and assembler;
[verilog netlist for instance]
- generate with ise/quartus required memories, interfaces [the body of your
'black boxes'];
add the netlist and tool [ise/quartus] specific macros [coregen/megawizard] to
your project and compile;
black box is an entity/module with ports declarations only, without any body;
[without any logic]
