venkateshem
Junior Member level 1
- Joined
- Dec 14, 2010
- Messages
- 15
- Helped
- 4
- Reputation
- 8
- Reaction score
- 4
- Trophy points
- 1,283
- Location
- coimbatore
- Activity points
- 1,356
Hello,
I hope I'm writing this post in the right thread. I'm new to PIC programming and would like some help. I too have a similar error as described in this thread, i.e.
Erasing...
Erase device complete
Programming...
The following memory regions failed to program correctly:
Program Memory
Address: 00000200 Expected Value: 000000bb Received Value: 00000000
Programming failed
Also, if I do as suggested above, I have the same:
Erasing...
Blank Checking...
The following memory regions failed blank check:
Program Memory
Address: 00000200 Expected Value: 000000ff Received Value: 00000000
Blank check failed
I am using MPLAB IDE v8.56, mpasmwin.exe v5.37, mplink.exe v4.37, mcc18.exe v3.36 and mplib.exe v4.37
I am using a MPLAB ICD 3 via USB and attempting to program a PIC18F2320 device.
These errors occur with Original project and Modified projects.
I have read on the web that the above may be caused through incorrect 'Configuration Bit Settings'. However, the original project has these set in code.
Any ideas? Any help would be most appreciated.
Many thanks,
Erasing...
Programming...
Program Memory
Programming failed
Erasing...
Blank Checking...
Program Memory
Blank check failed
Many thanks,
