Hi ,
My memories/macros .lib has internal clock insertion delay defined on CLK pin of memory/macro with propert max/min_clock_tree_path . we have concern over register to memory paths where capture path is memory.
If i consider one register to memory path . Tool is balacing well register with memory with including internal memory latency with 100 ps skew . But if we consider till CLK pin of memory the skew between register and memory CLK pin(in this case no internal latency) becomes around 500 ps which is creating a very large violation during report_timing .
I believe tool s doing right thing only reporting is issue . Please correct if i am wrong . If i am correct , please help on how to consider internal macro latency as well during report timing .
Thanks in advance ,
Argha
