Memory for extern variable
M.RAMARAO
Newbie level 3
Newbie level 3
if we declare a variable as external(with "extern" keyword) where the memory will be allocated for this variable? or it will be allocated or not?
can anyone give me the clarification about this please..............
An external declaration is a reference to an otherwhere globally defined variable.
Without the definition, no storage is allocated and an "undefined object" error asserted.
All your program if it is a single file or spanned into multiple files gets compiled into one .hex file which is burned to the microcontroller. So, all your program will use the same ROM and RAM in the micro. Declaring a variable or function as extern is related only for the Compiler. If the Compiler encounters extern when Compiling then it know that the variable or function is in some other file. If the extern variable is a global variable then space will be allocated for it, if it is a non global variable then it gets created when the particular function is called.
