Hello everybody
I have a Tektronix TDS 210 oscilloscope and I want to use it for measuring the output current of an electronic ballast. I don't have a current probe, actually the only method available to me is by using a shunt. Now, I don't really have a shunt either so I tried using 3.5 m long, 0.25 mm diameter,copper wire ( if I calculated correctly it should have about 1.4 ohms). I connected my shunt (the wire) in series with the neutral line and with the luminaire (the ballast). A wall outlet (231 V line to ground voltage) is my power source. I used two 10x probes for both channels and the math function Ch1-Ch2. The signal a got was: a peak, a few milliseconds zero then a peak but with an opposite polarity. Now this seems logical, but I want to see how far from a sinusoidal form is the current signal and this is far from a clean signal. It should look like a slightly misshaped sine wave. So my questions are:
- Can I use this wire as a shunt or do I have to find longer one (considering the signal I'm getting seems to be that way because the voltage difference is too low)?
- Am I doing something else wrong in the measuring?
- Is it even possible to measure the current with this method (and with this oscilloscope)?
Any help is appreciated, thank you in advance, and of course if something is unclear about my problem I will try to explain additionally.
