For Slew Rate, wire a -1 configuration and put a squared signal in the input. Then at one transition measure ΔVo= Vmax - Vmin, and Δt= tfinal -tinitial.
SR = ΔV/Δt
Added after 4 minutes:
FOr CMRR Ad/ Ac
At open loop put a dirferential signal very small like a sinusoidal one, reduce until you don't have any distortion at output, Ad = Vo/Vi.
Ac = Vo/Vi but the same signal at both inputs, here you must increase Vi until you can get a signal at putput.
FOr Power I don't know yous simulator but you must use a Wattmeter and measure Power in every device, and add all.
