armghan11
Member level 1
1) I want to measure current passing through main supply 220V AC 50HZ and fed it to the ADC of micro controller... what type of rectifier and filtering circuit should i use ? i am working on non intrusive load monitoring system... which identify loads on the basis of current signal.
Note:I don't want to use step down transformer
2) I am attaching one circuit suggest to me by someone... the 0.22ohm is a shunt resistance attached with neutral line of supply to measure current...
if i use the circuit given in figure.. what adc calculation i need to get current.
