vortex3
Hello guy,
I'm trying to read the position of a potentiometer from a long distance. My idea is to use a constant current passing throw the potentiometer and then using two instrumentation op-amp with a analog MUX and a 16bits ADC for reading the voltage drop on the hole potentiometer and on the cursor position. I will use two cables for the current path, one cable from the "bottom" of the potentiometer to both the negative inputs of the op-amps, one cable from the cursor to the positive input of one op-amp and one cable from the "top" of the potentiometer to the positive input of the second op-amp. At the end I can calculate the position of the potentiometer dividing the to voltage values.
Do you think this is a good idea? Any suggestion or comment will be welcome!
Thanks!
Thanks!
