meanig of mod 10 in mikrobasic
judfid
Member level 3
Member level 3
(char/1000) mod 10, what does this mean in mikrobasic.can this. be written in asm?
Yes. It can be written in asm. When you want to convert int or float value like 2345 to string"2345" then you extract single digit of the number and convert it to sting by adding 0x30 or decimal 48. If you reverse it you get the integer value.
If your num is 12345 then num/1000 gives 12 (integer value)
12 mod 10 gives the remainder 2
Remember / gives the quotient and mod gives remainder.
