Jul 16, 2005 #1 C cmos babe Full Member level 4 Joined Jan 15, 2005 Messages 209 Helped 11 Reputation 22 Reaction score 0 Trophy points 1,296 Location Dubai Activity points 1,897 mealy serial adder Hi, There are different outputs for different inputs at the transition conditions as you see in the state diagram,how should I fill the Condition and Outputs text boxes in StateCad "Edit Condition" window? Thanks.
Jul 23, 2005 #2 S shmoib Junior Member level 3 Joined Apr 9, 2005 Messages 30 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,559 serial adder mealy why dont you write the code directly , it will give you more abilities
Jul 23, 2005 #3 C cmos babe Full Member level 4 Joined Jan 15, 2005 Messages 209 Helped 11 Reputation 22 Reaction score 0 Trophy points 1,296 Location Dubai Activity points 1,897 mealy adder I want to learn how to use StateCAD... and I can't find any simple examples to start with..
Jul 23, 2005 #4 papyaki Advanced Member level 2 Joined Apr 13, 2002 Messages 537 Helped 38 Reputation 76 Reaction score 19 Trophy points 1,298 Location France Activity points 5,346 statecad examples Hi Here are some tutorials or help files : h**p://ece.wpi.edu/~rjduck/state_cad_tutorial.pdf h**p://toolbox.xilinx.com/docsan/xilinx7/help/iseguide/mergedProjects/state/state.htm (this one needs java). h**p://tutor.al-williams.com/fsm-1.htm Replace * by t
