[SOLVED] MCU based circuit design for electrical noisy environment
Amardeep
Junior Member level 3
Hi .. Everyone
i am going to use MCU for industrial application. industrial environment is so noisy and so much vibration, extreme temperatures, and humidity
can any suggest me for precaution while design a circuit
Thanks
Re: MCU based circuit design for electrical noisy nvironment
Read documents in attachment.
Hi .. Everyone
Thanks
Parts should be selected from industrial or military range of temperature usage.
For chemicals, water and humidity and vibrations cure can be epoxy mass or some laquir over all parts and over whole PCB from both sides.
Read note in particular part datasheet for usage in noisy environments.
  • Atmel - Microcontroller in a Harsh Environment.pdf
  • ST - Designing with Microcontrollers in Noisy Environments.pdf
  • FC - How To Develop a Robust Software in Noise Env.pdf
  • IC Hause - White Paper.pdf
  • Intel - Designing Microcontroller in Noise Env.pdf
Hi tpetar Thank you so much
