malik_zohaib
Full Member level 5
Hi guys.
I wanna ask if someone knows is there any jumper setting in mcquay air conditioning thermostat so it can remember the user set temperature; means when I set the temperature and off the system after that when I on it again it goes back to the default set temperature not mine set temperature.
the thermostat is https://es.aliexpress.com/item/The-...-air-conditioning-thermostat/32485523390.html
and jumper setting(on thermostat pcb) is :
