kaning
Junior Member level 3
- Joined
- Jul 17, 2014
- Messages
- 27
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 226
HI,
Im building a lipo charger with IC MCP73831 and im having some issues.
First one is after i mounted the circuit (5,1v supply) i got a output reading of 4,3v (i ordered 2ACI/OT,Vout=4,2v),on top says KD0W. is this value normal?? lipo betteries are very sensitive to overcharge so im afraid something goes wrong..
Second issue is about heat.
im using 16v solar panel, then step down converter with vout=10v to get more current into circuit. from here im using normal regulator with vout=5v to feed MCP73831 with is drawing 500mA. to simulate i was using laptop transformer with 19v 4,7A, the thing is regulator is heating a lot!! (im using heat sink) if im correct regulator is dissipating (10-5)*0.5=2,5W and it burns... and correct me if im wrong the current you get in the circuit is the current that circuit needs only right? so why its heating so much to regulate 5v?
many thanks
many thanks
