MAX232 and AT commands
thunderfsi
Newbie level 3
Newbie level 3
Hi everyone, I'm having a problem on my circuit. I send AT commands from PIC. After they pass MAX232 "AT" turns into "_" and enter command turns into "y". I'm new to these stuff. Can anyone please help ?
Circuit: View attachment v1.3.rar
sbit LCD_RS at RC0_bit;                 // LCD_RS assigned to PORT RC0;
sbit LCD_EN at RC1_bit;                 // LCD_EN assigned to PORT RC1;
sbit LCD_D4 at RC2_bit;                 // LCD_D4 assigned to PORT RC2;
sbit LCD_D5 at RC3_bit;                 // LCD_D5 assigned to PORT RC3;
sbit LCD_D6 at RC4_bit;                 // LCD_D6 assigned to PORT RC4;
sbit LCD_D7 at RC5_bit;                 // LCD_D7 assigned to PORT RC5;
sbit LCD_RS_Direction at TRISC0_bit;    // LCD_RS assigned to TRIS C0;
sbit LCD_EN_Direction at TRISC1_bit;    // LCD_EN assigned to TRIS C1;
sbit LCD_D4_Direction at TRISC2_bit;    // LCD_D4 assigned to TRIS C2;
sbit LCD_D5_Direction at TRISC3_bit;    // LCD_D5 assigned to TRIS C3;
sbit LCD_D6_Direction at TRISC4_bit;    // LCD_D6 assigned to TRIS C4;
sbit LCD_D7_Direction at TRISC5_bit;    // LCD_D7 assigned to TRIS C5;
#define OSC 20
void main(){
     ADCON1 = 0x06; //Analog to Digital Conversion
     TRISA=0xFF;   //Set PORTA as Input
     TRISB=0x00;   //Set PORTB as Output
     TRISC=0x80; //set direction of PORTC6 as output -- TX -- transmitter //set direction of PORTC7 as input -- RX -- reciever
     TRISD =0x00;
     TRISE =0x00;
     RB0_bit=0;
     UART1_init(9600);  // Initialize UART at 9600bpm
     delay_ms(1000);
     Lcd_Init();
     Lcd_cmd(_LCD_CLEAR);
     Lcd_cmd(_LCD_CURSOR_OFF);
     UART1_Write_Text("AT");
     delay_ms(1000);
     UART1_Write(0x0D); // ENTER
     delay_ms(2000);
     Lcd_Out(1,1, "Message Sent");
     delay_ms(3000);
It is very much a timing or clk problem.
Check with your scope the data rate if it is 9600 as you have set.
Then check all your clk, UART settings again.
What do you read the data with, a PC?
The max232 only inverts the logic(logic1=-v and logic0=+v), and does not add anything to the data itself.
If you read one character for the two sent, there is a mismatch in baudrate between the sender and the receiver.
The problem should be with baudrate mismatch of the PIC & the PC.
For PIC use 9600 and check in PC for 9600, baudrate should match.....
check it once.......
