kak111
MAX13301
4-Channel, Automotive Class D Audio Amplifier 4 x 80W
The MAX13301 combines four high-efficiency Class D amplifiers with integrated diagnostic hardware for reliable automotive
audio systems, and delivers up to 80W at 10% THD+N per channel into 4Ω when operating from a 24V supply.
The internal diagnostics evaluate each channel's output impedance to check for shorts across the outputs, to the battery,
or to ground. The I²C interface allows the system to query critical device parameters such as device temperature and output clipping.
The device is programmable to four different I²C addresses.
The audio amplifiers feature single-ended analog inputs with a common negative input. The MAX13301 has a fixed gain of 26dB.
The Class D amplifier has 10 programmable switching frequencies between 300kHz and 750kHz.
The BTL outputs are protected against short circuits and thermal overload. The outputs can be configured as a 2-, 3-, or 4-channel amplifier.
The device provides 50V load-dump protection, and is offered in the thermally enhanced, 48-pin TSSOP-EPR package operating
over the -40°C to +125°C temperature range.
