IF(CLK'EVENT AND CLK = '1') THEN
FOR I IN 0 TO PORT_SIZE-1 LOOP
IF(START_RX(I) = '1')THEN
PORT_RX(I) := TO_INTEGER(UNSIGNED(RX_MATRIX(I)(1 DOWNTO 0))); -- GET PORT ADDRESS
PORTMATRIXA(I)(PORT_RX(I)) <= PORTMATRIXA(CARD_RX)(PORT_RX(I)) + 1; -- INCREMENT MATRIX POSITION
END IF;
TYPE CARD_MATRIX IS ARRAY (0 TO PORT_SIZE-1, 0 TO 7) OF INTEGER RANGE 0 TO 256;
SIGNAL CARD_MATRIXA : CARD_MATRIX;
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.NUMERIC_STD.ALL;
USE WORK.TSS_4PORT_PKG.ALL;
ENTITY VOQ_MATRIXX IS
PORT (
CLK, ENABLE, RESET : IN STD_LOGIC; --! CONTROL SIGNALS
WRT_MATRIX : IN STD_LOGIC_VECTOR(PORT_SIZE-1 DOWNTO 0); --! SIGNAL INFORMING THE MATRIX THAT IT WILL BE UPDATED.
RX_MATRIX : IN MATDATA_TYPE; --! HEADER DATA FROM RX THAT WILL BE INCREMENTED.
CUT_MATRIX : IN STD_LOGIC_VECTOR(PORT_SIZE-1 DOWNTO 0); --! DECRIMENT MATRIX COUNT
TX_MATRIX : IN MATDATA_TYPE; --! HEADER DATA FROM FETCH THAT WILL BE DECREMENTED.
CARD_MATRIXB : OUT CARD_MATRIX(0 TO PORT_SIZE-1)(0 TO 7) --! INTEGER ARRAY HOLDING THE VALUE OF THE MATRIX ARRAY USED REPRESENTING THE LENGTHOF QUEUES PER INPUT PORT FOR CARD 1.
END VOQ_MATRIXX;
-- MATDATA_TYPE 16 ADDRESS WITH 8 BINARY LENGTH
-- PORTMATRIX_TYPE 256 ADDRESS WITH INTEGER RANGE 0 - 4095
ARCHITECTURE BEHAVIOUR OF VOQ_MATRIXX IS
SIGNAL START_RX : STD_LOGIC_VECTOR(PORT_SIZE-1 DOWNTO 0) := (OTHERS=>'0'); --! USED TO DETECT THE POSITIVE EDGE OF EACH INCREMENT REQUEST
SIGNAL START_RX_N : STD_LOGIC_VECTOR(PORT_SIZE-1 DOWNTO 0) := (OTHERS=>'0'); --! USED TO DETECT THE POSITIVE EDGE OF EACH INCREMENT REQUEST
SIGNAL START_TX : STD_LOGIC_VECTOR(PORT_SIZE-1 DOWNTO 0) := (OTHERS=>'0'); --! USED TO DETECT THE POSITIVE EDGE OF EACH DECREMENT REQUEST
SIGNAL START_TX_N : STD_LOGIC_VECTOR(PORT_SIZE-1 DOWNTO 0) := (OTHERS=>'0'); --! USED TO DETECT THE POSITIVE EDGE OF EACH DECREMENT REQUEST
TYPE TXHEAD_TYPE IS ARRAY (0 TO PORT_SIZE-1) OF STD_LOGIC_VECTOR(3 DOWNTO 0); --! OUTPUT HEADER PORT_SIZE - 1
SIGNAL TX_HEAD : TXHEAD_TYPE; --! CHECKS THE VALUES OF THE HEADER. SIMULATION DUMMY.
SIGNAL TX_OUTPUT : INTEGER_ARRAY4 := (OTHERS => 0); --! TRACKS THE DECRIMENTS PER PORT
TYPE CARD_MATRIX IS ARRAY (0 TO PORT_SIZE-1, 0 TO 7) OF INTEGER RANGE 0 TO 256; --! MATRIX ARRAY FOR COLOR-CARD
BEGIN
CARD_MATRIXB <= CARD_MATRIXA;
--PROCESSES
REQUEST_EDGE: PROCESS (CLK)
BEGIN
IF (CLK'EVENT AND CLK = '1') THEN
START_RX_N(I) <= NOT (WRT_MATRIX(I));
START_RX(I) <= (START_RX_N(I) AND WRT_MATRIX(I));
START_TX_N(I) <= NOT (CUT_MATRIX(I));
START_TX(I) <= (START_TX_N(I) AND CUT_MATRIX(I));
END LOOP;
END IF;
END PROCESS REQUEST_EDGE;
UPDATING: PROCESS(CLK, RESET)
VARIABLE PORT_RX : INTEGER_ARRAY4; -- HAS RANGE OF 16 ADDRESS WITH 0-15 VALUES
VARIABLE PORT_TX : INTEGER_ARRAY4;
BEGIN
IF (RESET = '0') THEN
CARD_MATRIXA <= ((OTHERS=>0));
ELSE
IF (RX_MATRIX(I)(4) = '0') THEN
CARD_MATRIXA(I,PORT_RX(I)) <= CARD_MATRIXA(I,PORT_RX(I)) + 1; -- INCREMENT MATRIX POSITION
ELSE
CARD_MATRIXA(I,PORT_RX(I)+PORT_SIZE) <= CARD_MATRIXA(I,PORT_RX(I)+PORT_SIZE) + 1; -- INCREMENT MATRIX POSITION
END IF;
END IF;
IF(START_TX(I) = '1') THEN
PORT_TX(I) := TO_INTEGER(UNSIGNED(TX_MATRIX(I)(1 DOWNTO 0))); -- GET PORT ADDRESS
IF (TX_MATRIX(I)(4) = '0') THEN
CARD_MATRIXA(I,PORT_TX(I)) <= CARD_MATRIXA(I,PORT_TX(I)) - 1; -- DECREMENT MATRIX POSITION
ELSE
CARD_MATRIXA(I,PORT_TX(I)+PORT_SIZE) <= CARD_MATRIXA(I,PORT_TX(I)+PORT_SIZE) - 1; -- DECREMENT MATRIX POSITION
END IF;
END IF;
END LOOP;
END IF;
END IF;
END PROCESS UPDATING;
END BEHAVIOUR;
What would be my type declaration for CARD_MATRIX if I wanted to make it as an output in my port declaration? would it be integer?
Code:TYPE CARD_MATRIX IS ARRAY (0 TO PORT_SIZE-1, 0 TO 7) OF INTEGER RANGE 0 TO 256; SIGNAL CARD_MATRIXA : CARD_MATRIX;
It is like I wanted to make PORTMATRIXA consist of four arrays with integer values. So I can have, PORTMATRIXA(0) = 1 2 4 12 4 12 34 43, PORTMATRIXA(1) = 12 7 3 12 44 12 4 2 and so on. in which each array is created inside the FOR LOOP.
If CARD_MATRIX is declared as above, then you're declaraing it wrong. It has already been decalred with sizes in the type definitiion.
More direct -- remove the sizes. Just use "CARD_MATRIX" instead of "CARD_MATRIX(range,range)"
also, you have a range of 0 to 256. This is a 9 bit value. You probably wanted either 0 to 255 or 0 to 511.
LIBRARY IEEE;
PORT (
CARD_MATRIXB : OUT CARDMATRIX_TYPE --! INTEGER ARRAY HOLDING THE VALUE OF THE MATRIX ARRAY USED REPRESENTING THE LENGTHOF QUEUES PER INPUT PORT FOR CARD 1.
END VOQ_MATRIXX;
TYPE CARDMATRIX_TYPE IS ARRAY (0 TO PORT_SIZE-1, 0 TO 7) OF INTEGER RANGE 0 TO FIFO_SIZE; --! MATRIX ARRAY FOR COLOR-CARD
SIGNAL CARD_MATRIXA : CARDMATRIX_TYPE;
BEGIN
--PROCESSES
BEGIN
END LOOP;
END IF;
BEGIN
CARD_MATRIXA <= ((OTHERS=>(OTHERS=>0)));
ELSE
ELSE
END IF;
END IF;
ELSE
END IF;
END IF;
END LOOP;
END IF;
END IF;
END BEHAVIOUR;
For clarity, you should not repeat the type declaration in the entity body, just use the declaration from the package.
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/vrfx_verific_elaborator.cpp, Line: 2144
c
Stack Trace:
0x61d46: VRFX_ELABORATOR::elaborate + 0x8566
0x61c87: VRFX_ELABORATOR::elaborate + 0x84a7
0x61167: VRFX_ELABORATOR::elaborate + 0x7987
0x6041f: VRFX_ELABORATOR::elaborate + 0x6c3f
0x599cc: VRFX_ELABORATOR::elaborate + 0x1ec
0xc50b3: sgn_clear_check_ip_functor + 0x3aeb3
0xc8d7f: sgn_clear_check_ip_functor + 0x3eb7f
0xca666: sgn_clear_check_ip_functor + 0x40466
0x92834: sgn_clear_check_ip_functor + 0x8634
0xa37fc: sgn_clear_check_ip_functor + 0x195fc
0xa79ee: sgn_clear_check_ip_functor + 0x1d7ee
0x10d12: sgn_qic_full + 0x152
0x11fad: qexe_get_command_line + 0x1b7d
0x14e0e: qexe_process_cmdline_arguments + 0x59e
0x14f21: qexe_standard_main + 0xa1
0x4ae8: msg_exe_fini + 0x58
0x522c: msg_exe_fini + 0x79c
0x1524: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5e0f: msg_exe_main + 0x8f
0x8363: BaseThreadInitThunk + 0x13
0x670d0: RtlUserThreadStart + 0x20
End-trace
