imonline888
Newbie level 1
Hello. I am a newbie in Matlab Simulink. My professor gave me some specifications and parameters and my task is to find suitable application/system to be simulated in matlab by using Simulink. Below is the specs he gave:
Input Freq: 12KHz
Transistion band: Fs(start) - Fs(stop): 0.255-0.355
Input signal (voltage): 1.6 V
ripple voltage: 0.02 V
clock frequency: 120KHz
the system must be with 12-bit input discrete signal
the system must be with N-bit from 3-4 bit
the system must be using the supply voltage not greated than 2.5V
I should be able to show how I design my zero and dc gain and reach the desired SNR for N bit input using POwer Spectrum Analysis. I should also use the vale Fs within voice bandwigth range.
I would like to come up with a matlab simulation by using simulink. I think it may not be necessarily that the system uses all of those specs as long as it has almost all of the specifications required. I am also allowed to add some specs bases on my design as long as Im using almost everything he had specified.
Pls help me...thanks in anticipation
--- God Bless and more power
Input Freq: 12KHz
