steph_smile09
Newbie level 5
matlab mse
heloo evryone...
can you help me to analyze this program... can you explain it to me??step by step???please...im doing a thesis about echo cancellation...using adaline network.. using LMS algorithm..and i dont know if this is the correct program for my thesis.. please help me.. i reaaly need your help
this is the program..
clear all;
mu = .01; %Larger values for fast conv
max_run = 200;
for run=1:max_run;
taps = 20; %Adaptive Filter order
freq = 2000; %Signal Freq
w = zeros(1,taps); %initial state of adaptive filter
time = .2; %lenght of simulation (sec)
samplerate = 8000;%samples/sec
samples = time*samplerate;
max_iterations = samples-taps+1;
iterations = 1:max_iterations;%Vector of iterations
t=1/samplerate:1/samplerate:time;
noise=.02*rand(1,samples);%noise added to signal
s=.4*sin(2*pi*freq*t);%Pure Signal
x=noise+s;%input to adaptive filter
echo_amp_per = .4; %Echo percent of signal
echo_time_delay = .05;
echo_delay=echo_time_delay*samplerate;
echo = echo_amp_per*[zeros(1,echo_delay) x(echo_delay+1:samples)];
%Adaptive Algorithm using LMS
for i=1:max_iterations;
y(i)=w*x(i:i+taps-1)';
e(run,i)=echo(i)-y(i);
w = w + 2*mu*e(run,i)*x(i:i+taps-1);
end
end
%%Mean Square Error
mse=sum(e.^2,1)/max_run;
b=x+echo;
%Ouput of System
out=b(1:length)-y;
subplot(3,1,1),plot(b);
title('Signal and Echo');
ylabel('Amp');
xlabel('Time sec');
subplot(3,1,2),plot(out);
title('Output of System');
ylabel('Amp');
xlabel('Time sec');
subplot(3,1,3),semilogy(mse);
grid
title('LEARNING CURVE mu=.01 echo delay=64ms runs=200');
ylabel('Estimated MSE, dB');
xlabel('Number of Iterations');
thank you very much...
heloo evryone...
clear all;
max_run = 200;
for run=1:max_run;
end
end
%%Mean Square Error
b=x+echo;
%Ouput of System
out=b(1:length)-y;
ylabel('Amp');
xlabel('Time sec');
ylabel('Amp');
xlabel('Time sec');
grid
