Matlab image processing doubt
abhigopal
Member level 3
I have an image matrix. I want to convert all the pixel values to binary values for processing. How do i do this?? Is there some kind of quantization format available??
Thanks
Abhi
tofinhk
Member level 1
What do you mean by converting pixel values to binary values?
if there is a 8-bit image, you got a value 129 from a pixel, then you want to change it to 1000 0001??
If so, what you need is a function change from decimal to binary, but not a image processing problem. As I remember, there is a function called dec2bin, you may check about it.
HTH
h_ghanei
You should use these functions in the order:
imread
double or im2double
dec2bin
abishek
Member level 1
the inbuilt function in matlab dec2bin should do the job
