BAT_MAN
Member level 5
Can anybody explain me the logic for the function file although comment are given but i was unable to understand
function Factors = factorize(polyn)
format long; Factors = [];
% Use threshold of 1e-8 instead of 0 to account for
% precision effects
THRESH = 1e-8;
proots = roots(polyn); % get the zeroes of the polynomial
len = length(proots); % get the number of zeroes
while(len > 1)
if(abs(imag(proots(1))) < THRESH) % if the zero is a real zero
fac = [1 -real(proots(1))];
% construct the factor with proots(1) as zero
Factors = [Factors;[fac 0]];
else % if the zero has imaginary part get all zeroes whose
% imag part is -ve of imaginary part of proots(1)
negimag = imag(proots)+imag(proots(1));
% get all zeroes which have same real part as proot(1)
samereal = real(proots)-real(proots(1));
%find the complex conjugate zero
index = find(abs(negimag) <THRESH & abs(samereal)<THRESH);
if(index) % if the complex conjugate exists
fac = [1 -2*real(proots(1)) abs(proots(1))^2];
%form 2nd order factor
Factors = [Factors;fac];
else % if the complex conjugate does not exist
fac = [1 -proots(1)];
end
end
polyn = deconv(polyn,fac);
%deconvolve the 1st/2nd order factor from polyn
proots = roots(polyn); %determine the new zeros
len = length(polyn); %determine the number of zeros
end
% precision effects
THRESH = 1e-8;
while(len > 1)
end
end
end
