jenabi
hii
i need help below is the code that is for dynamically changing the tap length of adaptive filter....but when i run this in matlab i get error saying that d(n:-1:n-L+1) cannot have negative indices...can someone tell me how to debug this...and where am i going wrong
clc;
clear;
delta = 2;
n_bits=15;
t=5000;
x = 0.5*((rand(1,t)>0.5)-.5);
r = 1;
imp = [-4.4 0 -7 -12 -9 -14 -20 -16.5 -20 -22.5 -20];
response = (10.^(imp/10));
quant = round(response*(2^n_bits));
quant = quant/2^n_bits;
channel = [0.4 1 0.2 0 0.06 0.1 0.04 0.01 0.02 0.01 0.005 0.01];
channel = channel.*2;
b = (randn(1,5)).*exp(-(0:4));
c = [1 0 -.3 0 .5 0 -.1 0 0.1];
% Generate noise
snr = 20;
n=1/sqrt(2).*(randn(1,length(x)));
noise = 10^(-snr/20)*n;
noise = 0.25.*noise;
var = 1;
noise_low_SN=0.55*(randn(1,t*r)*sqrt(var));
noise_low_q=round(noise_low_SN*2^n_bits)/2^n_bits;
noise_high_SN=0.01*(randn(1,t*r)*sqrt(var));
noise_high_q=round(noise_high_SN*2^n_bits)/2^n_bits;
noise = [noise_high_q];
% input signal
input = (filter(c,1,x));
%input = (x);
pad = zeros(1,delta);
pad1 = ones(1,4);
input_LMS = round(input*2^n_bits)/2^n_bits;
input_q = round(input*2^n_bits)/2^n_bits; %Quantisation for file output
input_des=round(x*2^n_bits)/2^n_bits;
%adaptive filtering
L = 9; % filter length
P = 3; % sub-filter size
mu = 0.005; % step size ( mu < 1/(L*std(x)^2) )
W = zeros(1,L); % adaptive coefficients are initialised to zero
ASE = 50;
e_array = zeros(1,ASE);
e_sub_array = zeros(1,50);
pad = zeros(1,L);
x_pad = zeros(1,L-3);
x_delay = [pad x];
d = [x_pad, input_LMS];
y = zeros(1,length(x));
e = zeros(1,length(x));
y_sub = zeros(1,length(x));
e_sub = zeros(1,length(x));
coeff = zeros(1,length(x));
for n = L:length(x)
n
L
X = d(n:-1: n-L+1);
y
= round((W*X')*2^n_bits)/2^n_bits; % adaptive filter out
X_sub = d(n:-1:n-L+(P+1));
W_sub = W(1:1
L-P));
y_sub
= round((W_sub*X_sub')*2^n_bits)/2^n_bits; % adaptive sub-filter out
% error signals
e
= (round((x_delay
- y
)*2^n_bits))/2^n_bits;
e_sub
= (round((x_delay
- y_sub
e_array(2:ASE) = e_array(1:ASE-1); % calculation of ASE
e_array(1) = (e
)^2;
e_sub_array(2:ASE) = e_sub_array(1:ASE-1);
e_sub_array(1) = (e_sub
)^2;
ASE_res = sum(e_array);
ASE_res_sub = sum(e_sub_array);
if (ASE_res <= ASE_res_sub) % evaluate Filter length
L = L + P; % to add or remove P taps
elseif (ASE_res >= ASE_res_sub)
L = L - P;
end
coeff
= (round(2*mu*e
*2^n_bits)/2^n_bits);
W = W + coeff
*X; % LMS update
W=(round(W*2^n_bits)/2^n_bits);
e_sq
= e
^2;
end;
thanks
clc;
clear;
delta = 2;
n_bits=15;
t=5000;
r = 1;
% Generate noise
snr = 20;
var = 1;
% input signal
%input = (x);
pad1 = ones(1,4);
%adaptive filtering
ASE = 50;
pad = zeros(1,L);
x_delay = [pad x];
for n = L:length(x)
n
L
X = d(n:-1: n-L+1);
y
W_sub = W(1:1
y_sub
% error signals
e
e_sub
e_array(1) = (e
L = L - P;
end
coeff
W = W + coeff
e_sq
end;
thanks
