yasine79
Member level 2
- Joined
- Nov 10, 2009
- Messages
- 49
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- germany
- Activity points
- 1,602
hi all!
i designed two similar antennas(transmitter and reciever). the maching of the antennas is (S11= -5dB). it is not good!
But the (S21=-14dB in Air),(S21=-30dB in water). the Antennas are used in the near field . the distance between both antenna is 70mm, the frequensy is the ISM BAND.
is the the matching so important also in this case?
the antenne is a dielectric feeded with a coaxial cable.
thank you
thank you
