Hello, all fellow geeks!
I am setting up a tape deck head input to a iPod line level output.
1VPP I believe. What was being used was a phony cassette, with the inductive
transfer coil, which presses against the head, creating a signal transfer transformer.
I want to go from iPod to head input (head disconnected), via a simple voltage divider for right an left channels.
My question is, what value resistors should I use to create the ratio to drop the signal level
from the 1VPP iPod output down to the approximate 5mV the head actually puts out normally, with tape.
I guess it would be called an impedance matching issue. I would think the head Z to be low,
but the head amp input to be high, so as to not load down the tiny, and low power head signal.
Thanks,
-Lisa
