master and slave Microcontrollers
garg29
Advanced Member level 1
writei2c(0xa1
I'm trying to design a project just for hobby.
Project is suppose i have to mesaure some physical
property let's say temperature of 10 different
locations each situated nearby only. i have to use
slave and master method as i have drawn in picture
below. what method should i follow for programming.
I'll be really thankful if someone can please provide
just brief example on this.
Thanks in advance.
Garg
slave writei2c
In this situations I use modbus (or mechanisams of modbus) or something similar (I do this on PLC's).
Master should put message:
ABCD
A - master address e.g. 01h
B - slave address e.g. 04h (third slave mcu)
C - command (give me temperature, or comething else, or put output pin 1 to "1" or ....), e.g. 01h give temp, 02h give time, 03h set output1 ....
D - checksum (there are many types of CS, so choose one...
Slave's should give answer:
ABCDE
A - slave address
B - master address (01h)
C - number of bytes which slave sending
D - data (C number of bytes data)
E - checksum
Regards,
Mr.Cube
    garg29
Thanks Mr.Cube. Should i use SCL & SDA type two wire link for whole network(as i have drawn). Sorry if it's too basic....i'm new to communications
Generaly,
You always can use i2c, it's made for this kind of communication (master - slaves).
I think you can find lots examples and codes on edaboard.
Best regards.
Mr.Cube
    garg29
i2c reminds me of ds1307 rtc chip which i tried to commnicate with 89c51 i did but with PIC microcontroller i was unsuccessful. With eeprom 24cxx i have done again with 89c uCs will i need to take same method as in the code attached
Thanks........with best regards.
Garg
#include<reg52.h>
#include<intrins.h>
#define ACK		1
#define NO_ACK	0
unsigned char i2;
sbit SDA  =  P1^7;	// connect to SDA pin (Data)
sbit SCL  =  P1^6;	// connect to SCL pin (Clock)
// start I2C
void Start(void)
    SDA = 1;
	SCL = 1;
	_nop_();_nop_();
	SDA = 0;
	_nop_();_nop_();
	SCL = 0;
	_nop_();_nop_();
// stop I2C
void Stop(void)
	SDA = 0;
	_nop_();_nop_();
	SCL = 1;
	_nop_();_nop_();
	SDA = 1;
// Write I2C
void WriteI2C(unsigned char Data)
	for (i2=0;i2<8;i2++)
        SDA = (Data & 0x80) ? 1:0;
		SCL=1;SCL=0;
		Data<<=1;
  	SCL = 1;
	_nop_();_nop_();
	SCL = 0;
// Read I2C
unsigned char ReadI2C(bit ACK_Bit)
    unsigned char Data=0;
    SDA = 1;
		SCL   = 1;
		Data<<= 1;
		Data  = (Data | SDA);
		SCL   = 0;
		_nop_();
 	if (ACK_Bit == 1)
	SDA = 0; // Send ACK
	else
	SDA = 1; // Send NO ACK
	_nop_();_nop_();
	SCL = 1;
	_nop_();_nop_();
	SCL = 0;
	return Data;
// Read 1 byte form I2C
unsigned char ReadBYTE(unsigned int Addr)
   	unsigned char Data;
	Start();
	WriteI2C(0xA0);
	//WriteI2C((unsigned char)(Addr>>8)&0xFF);	// ....not valid for small EEPROMs
	WriteI2C((unsigned char)Addr&0xFF);
	Start();
	WriteI2C(0xA1);
	Data = ReadI2C(NO_ACK);
	Stop();
   	return(Data);
// Write 1 byte to I2C
void WriteBYTE(unsigned int Addr,unsigned char Data)
	Start();
	WriteI2C(0xA0);
	//WriteI2C((unsigned char)(Addr>>8)&0xFF);	// send address high....not valid for small EEPROMs
	WriteI2C((unsigned char)Addr&0xFF);			// send address low
	WriteI2C(Data);
	Stop();
Here some i2c code examples.
Help yourself.
