Kindly get back to me with your view on this topic . whether I can measure frequency( Hz ) in this model if so which mode i have to setup in this multi meter or this model cannot measure this frequency ( HZ)
Thanks for your reply i have uploaded multi-meter image as an Insert image.kindly get back to me with your view on this. if you still not able to view this image please let me know
No there isn't. You would need a different DMM which has a frequency counter setting, or a frequency meter/counter. That multimeter only measures quantity-based values, not time-based values.
You could build a tachometer circuit and measure the voltage it produces. The voltage would be proportional to frequency but you would still have to do some math to convert voltage to its equivalent frequency and the highest frequency it would measure is likely only to be a few KHz.
