I also own a 2019th marconi ssg. It gives me error 25 on the display.
I've tried changing the microprocessor board. How many different versions exist of this generator? The card that was mounted employed ER3400 and also D8085 integrated circuits. Instead the parts does not have the ER3400 and uses a HY6116ALP instead of D8085 and has at most the Atmel AT28C17. Are compatible with each other the two cards or not?
