David_
Advanced Member level 2
Hello.
My friend has recreantly inherited his fathers very first amplifier, a Marantz Stereo FM/AM Receiver, Model 1515.
It does work although there are some problems like sometimes only one speaker works and sometime both works and there are some bad connections and noisy potentiometers. I am looking for advice on what can be and should be done to treat it as good as possible, we will take and dissemble the hole thing and really clean it and I plan to buy replacement components for some obvious stuff.
The brown mark on the inside of the chassis is the spot right above the two main bulk capacitors... Good sign.
We are going to go over the boards thoroughly and inspect all components but first of I am thinking of all the larger electrolytics, I was hoping that there are some things that one usually should do with old amplifiers like this.
The potentiometers are very specific and hard to replace I now that there are sprays that can improve them, what would you suggest?
This amplifier has a great sentimental value for my friend and although we don't have any hugh amount of money to spend we have some and want to make it as new condition as possible and any and all thought about this is greatly appreciated.
Regards
Regards
