In my place&route implementation in SoC Encounter, I'm placing certain instances and fix their positions by the command placeInstance -fixed , then I route between them manually by long close metals with minimum DRC (It's intentional for my task). The problem is that when I continue the implementation (placing) the standard cells and optimizing (Design) some of those connections are removed. Is there a way to fix those metal wires I drew manually so they are still connected till the end after all different steps?
