Make gerber to perfect alignment for CA*M350
bigfoot
Junior Member level 3
Hi all,
I have problem misalignment between route layers and NC drill when ever time I try to use Auto import function to import powerPCB gerber files into CAM350. I known, I can alignment in CAM350, but it takes too much time for me to do so. The thing is, I want to setting up offset of coordinator X, and Y, and force CAM350 100% precise alignment all layers as in powerPCB.
What is the trick I have to do? What is offset number to adjust?
Hoped, Expert PCB guy can help me on this.
Thanks
Bigfoot
You can set new NC drill origin point in C@M350. Put some referent pad e.g to left-down corner in Power PCB and import gerber files to C@M350. Than you can make relative offset with NC drill origin point to imported referent pad. I think that this is simpliest way to make NC drill offset.
