Mains voltage logger could do with more resolution
T
treez
We have done the attached mains voltage logger.
It works but the range of vout is small for 180vac to 265vac.
Do you have approximately-just-as-cheap optimisations for this?
Schem and LTspice sim attached.
  • InAmp Mains voltage logger.pdf
  • InAmp mains voltage logger.txt
Is your setup an expanded-scale meter? It's made by installing a zener diode inline with the voltage you're measuring. Select a value so 180V yields a reading just above the zeroline. Then condense your scale so 265V reads at the maximum your setup can handle.
If you first divide down the initial voltage, so it's in the realm of a few volts, then a plain diode is sufficient to create the expanded scale meter. (Or led, or a string of diodes, etc.)
Reactions: treez
    T
