rocsavi
Newbie level 3
dear all,
I worked on PHOTODETECTOR based project...In this project,input light from laser is coupled through fiber ....Near photodetector i have to place a coil near photodetector pcb ...there is no physically contact between photodetector pcb and coil...coil is driven by a function generator..when coil vibrates at desired frequency which is set by function generator..pcb also pick up same frequency signal and gives this as output..
pcb contanis LT1167 Amplifier which gives output,,,problem is that, frequency of required output signal and coil vibrating signal frequency both are same..i want to avoid coil signal that is captured by pcb...any suggestion p[lease...
