marrgony
Newbie level 1
This request is for a track 1,2,3 magnetic card reader that collects/stores all 3 tracks of data.
-The magnetic head and magnetic stripe will be ISO and 75 to 210 BPI, alphanumeric.
-Speed: card speed through the unit may vary from 3 ~1000 ips
-If possible, I would like the card data recovered even when the swipe has not been done correctly, jitter, half swipe, etc.
-Automatic Gain Control
-memory: 128K or higher, whatever the design will allow.
-USB interface- the mini/sub USB connector.
-Battery powered and low battery indicator/LED- 3.7V 65mA or greater, Lithium Polymer. This will need to be charged via USB.
-Time stamp shows date and time with every input
-Data downloadable to the computer via USB
-Auto Power Off /Switch Control
-MCU Standby Mode
-Password Protection
-Maybe 2 or 3 small LED's, for status and battery.
The battery and magnetic head will be off board, not further than 60mm away.
Now the fun part- I need this to be as small as physically possible. Under 5mm in width, under 3mm in height, the length can be up to 40mm.
I'm open to additional ideas and suggestions too, including software to access this.
Thank you
i offer money for this project
-MCU Standby Mode
Thank you
