Hi all,
In Astro we get max transistion and capacitance violations if any in the timing report itself and also options such as gate sizing and buffering can be enabled for fixing it.
In Magma hw do we find out these violations. the timing report gives only the setup and hold values and wat r the methods we can use to fix transistion and capacitance violations. is it same as gate sizing and buffering.
Also if we get zero slack and number of failing end points as 1. wat should be done in magma. I am getting one such situation after detail routing in which there are zero drc,lvs violations and hold slack is met. setup slack is 0 with 1 failing end point.
thankz.................................
