LoomVortex
Junior Member level 1
- Joined
- Apr 22, 2009
- Messages
- 16
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Kajaani, Finland
- Activity points
- 1,389
m1-sysmgmt-dev-kit
Hi!
I´m working with Actel´s M1-SYSMGMT-DEV-KIT board and I have a problem with communication between Fusion and ProAsic3. In this board ProAsic3 is only because of limited number of I/Os on the Fusion M1AFS1500 and so LCD, key pads, DIP switch and LEDs are connected to ProAsic3.
What I´m trying to do is write from Fusion to LCD via ProAsic3 and it´s not working. Fusion sends serial data from CoreUARTapb correctly (tested with HyperTerminal), but in ProAsic3 receive is not working properly/at all. For receiving I´m using CoreABC processor which reads data from CoreUARTapb and passes data to CoreGPIO where LCDs control code is connected. "Normal" writing (when I write only one character from CoreABC) to LCD works ok.
If someone has any experience about this, please help.
-Jarno Kauppinen
Hi!
-Jarno Kauppinen
