Good evening.
I am simulating in HFSS a short dipole, as well as a small loop antenna. The purpose is calculating the coupling between two short dipoles or two short loops. To match these antennas I use as excitation a lumped port with the same resistance and opposite reactance than the measured Zin, however, when I use this lumped port whith different impedance than 50Ohms the simulation returns S parammeters larger than 0dB... Which could be the problem?
Thank you very much.
