[SOLVED] LTSpice simulation files conversion from text file
decook1110
This very long post about PSFB vs LLC Full Bridge from 2016 has 10 links in it to what appear to be LTSpice files.
It was a very informative discussion over 5 pages, but the LTSpice models are attached to the forum posts as text files. I'm just starting with LT spice and can't figure out to do with these old files.
Does anyone have pointers or links I should go to that discuss this?
Thanks
Dave
Did you try to rename .txt to .asc?
Edaboard doesn't support upload of .asc, they have to be zipped or - renamed.
..also , beware, LTspice has been updated and some of the diodes will come out as general purpose diodes and of the wrong voltage, instead of superfast diodes...but you can replace them.
