Ajay Renganathan
- Joined
- Aug 12, 2014
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 46
Hello all.
I have a question regarding the editing of the LT3652 test circuit.
I am trying to charge a 12V 7Ah SLA battery(Max 2.1A, Float vtg 13.5V) using a 10W Solar panel (Voc=21V, Isc=0.6A, Vmp=17.6V Imp=0.57A).
The test circuit is for an input of 16V and output current of 1A and voltage of 11.7V(as seen from the waveform after simulating).
I require a min. input voltage of 17V and need to charge the battery with the given specs above. I edited the voltage divider to get the input voltage as well as the Rsense resistor to set the maximum current as 2A.
I'm getting an output voltage of 9.9V though. I know that .ic is for initial conditions but when I change that value I get the same changed value as the output voltage. I am not able to see the voltage increasing to the float voltage in this circuit whereas in the test circuit I am able to.
Is there some mistake that I've made? Can anyone help me out with what I need to do?
