I'm trying to create a simple current source in LT spice, but my simulation results are total s---.
It doesn't look like anything.
My idea is, I plug 1 volt in, that voltage creates a current through the resistor which makes a voltage steadily grow over the capacitor.
But LT spice just prints some bull--- squiggly lines that changes a few pV maximum.
After fixing the error, you also need to set the "skip initial transient solution" option to make the simulation work. Otherwise it starts with the capacitor fully charged.
If needed you have components called "current" in LTSpice. Also you can use "g", "g2" or "h" compoenent to create voltage dependent source.
Try your circuit with replacing V1 with a pulse signal from 0V to 1V with a fast rise time.
