Hi
I have designed a board using LPC2388 and a SD card class 10.
I use RL-ARM library for interfacing SD card in Native 4-bit mode.
Every thing is Ok, but a problem exist. The write speed on SD card is very low (about 1MBPS).
I expect at least 3-4 MBPS, when I inspected more deeply I understood that when microcontroller send a command to SD card,
in most of the times a command time-out occurs. I don't know why this occurs. Can any body help me?
