Lpc2148 uart interrupt
rngarun
Newbie level 2
Newbie level 2
Hello All
I am using LPC2148 and I am struggling to find an example code for Interrupt driver UART. There are some samples which are not working. Can anyone send me a small example using Interrupt driven uart0 for keil compiler please.
Thanks
This code working in keil compiler .. for UART0 using BAUD RATE 9600
You can able to check in Hyper Terminal
#include  <lpc214x.h>		 //Includes LPC2148 register definitions
#define Fosc            12000000
#define Fcclk           (Fosc * 5)
#define Fcco            (Fcclk * 2)
#define Fpclk           (Fcclk / 4) * 1
#define  UART_BPS	9600	 //Set Baud Rate here
const unsigned char SEND_STRING[] = "UART TEST";
const unsigned char SEND_STRING1[] = "Test Passed\n";
unsigned char received_data;
void  Delay_Ticks(unsigned int Delay)  //Function to generate finite delay
   unsigned int i;
   for(; Delay>0; Delay--)
   for(i=0; i<50000; i++);
void  Init_UART0(void)					//This function setups UART0
   unsigned int Baud16;
   U0LCR = 0x83;		            // DLAB = 1
   Baud16 = (Fpclk / 16) / UART_BPS;
   U0DLM = Baud16 / 256;
   U0DLL = Baud16 % 256;
   U0LCR = 0x03;
void  UART0_SendByte(unsigned char data)	   //A function to send a byte on UART0
   U0THR = data;
   while( (U0LSR&0x40)==0 );
void  UART0_SendStr(const unsigned char *str)	 //A function to send a string on UART0
   while(1)
      if( *str == '\0' ) break;
      UART0_SendByte(*str++);
int  main(void)
   PINSEL0 = 0x00000005;		    // Enable UART0 Rx and Tx pins
   PINSEL1 = 0x00000000;
   PINSEL2 = 0x00000000;
   Init_UART0();
   while(1)
   UART0_SendStr(SEND_STRING);
   while((U0LSR&0x01)==0);
   received_data = U0RBR;
   UART0_SendByte(received_data);
   return(0);
I Hope its helps you..
