lpc2148 code not executing
jayanthyk192
Full Member level 3
Full Member level 3
I starting to work with LPC2148 MCU. I bought a daughter board with the IC in it. It has the crystal connected, Vss and Vdd supplied with proper voltages. I added a 12k to reset and pulled it up. I used a 12k at PO.14 and pulled it up. I'm able to burn the flash, but the code is not running. Another problem is that, when i pull the PO.14 to gnd, even without resetting, the bootloader is enabled. then after burning flash the reset works but code doesnt. I have left all JTAG pins as it is, not pulled up or down. I even added a capacitor at reset but no change. Please help me solve the problem. I had a similar problem with LPC2106 because of clock problem. But i tried changing it and it still doesn't work
Thank you
Try this.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
#include<lpc21XX.h>
int main()
 IODIR0 = 0X4000; //P0.14 as output
 IODIR1 = 0X0001; //P1.0 as output
while(1)
 IOSET1 = 0X0001;
 IOSET0 = 0X4000;
 //add delay of min 500 ms here
 IOCLR1 = 0X0001;
 IOCLR0 = 0X4000;
Try this.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
#include<lpc21XX.h>
int main()
while(1)
 IOSET1 = 0X0001;
 IOSET0 = 0X4000;
 IOCLR1 = 0X0001;
 IOCLR0 = 0X4000;
I burnt the microcontroller :sad:. I was trying to reconnect wires and i let one of the pins touch a 5V rail. I ended up burning the microcontroller. I'll get back if there are any problems in the new one i"m buying today.
