LPC2129 power on reset
binojkumar
Full Member level 3
Bangalore
lpc2129
Hi friends, im working on LPC2129, Its LCD program is not working on power on reset. After turning on its requires a press on reset button for displaying the LCD.
I have put proper delay on the begining of the program but its not working as i expected.
pls help me
VC
pwer on reset of lpc2129
Tell us the about the code, board name.
lpc2000 power on reset
binojkumar said:
I have put proper delay on the beginning of the program but its not working as i expected.
Did you use a proper reset circuit or just an RC? If you just used an RC that might not be sufficient for the older LPC2000 devices such as the LPC2129. There is no internal reset circuit and it is not important to have the delay in software at the beginning of the program, it is important to have a long enough time before the MCU tries to execute code. Once your delay loop executes correctly, you might as well drop it ;-)
Bob
http://www.lpc2000.com
lpc2129 lcd interfacing program
HI the Problem may be the LCD Initialize function. Check up with the datasheet of that LCD and do the proper initialization.
The Problem i faced and rectified too. I am sure the problem on initiliase section only.
So Check up with that.
power-on-reset
the problem is due to RC reset circuit
use better reset circuit or put long delay
