xpress_embedo
Hello!! Everyone
I am new in the filed of Cortex-M3 and using LPC1343 micro-controller for my project, which also requires a USB HID.
I found USB HID demo in Keil Example folders and by using the USB Stack i created my project, which is exactly similar to example project provided by Keil.
I have to send some data from LPC1343 to PC and from PC to LPC1343, for Sending data from LPC1343->PC In Endpoints are used and for PC->LPC1343 OUT Endpoints are used.
The main Code is as follow:-
But as per this code, LPC1343 is sending data continuously to PC, i tried to find the reason behind this, and i found this code in usbuser.c file
I think this code is automatically called after some time and due to this i am getting data on PC
Can any one tell me, how can i send data to PC only at specific changes, not continuously.
Call this function, whenever i need to send some data will do my work ( my assumption, haven't tried this), is it right method to do so
USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport));
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 // HID Input Report u8_t InReport; // HID Output Report u8_t OutReport; // Get HID Input Report -> InReport void GetInReport (void) { InReport = 0x01; return; } // Set HID Output Report <- OutReport void SetOutReport (void) { if(OutReport == 0x01) { LPC_GPIO1->DATA &= ~(1<<GreenLED); } else if(OutReport == 0x02) { LPC_GPIO1->DATA &= ~(1<<BlueLED); } else { LPC_GPIO1->DATA |= (1<<GreenLED); LPC_GPIO1->DATA |= (1<<BlueLED); } return; } int main() { InitializeSystem(); USBIOClkConfig(); // GPIO's Power is enabled by default // Set Pins as Output pins. LPC_GPIO1->DIR |= (1<<GreenLED); LPC_GPIO1->DIR |= (1<<BlueLED); // USB Initialzation USB_Init(); // USB Connect USB_Connect(TRUE); while(1) { // Do Nothing } }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 /* * USB Endpoint 1 Event Callback * Called automatically on USB Endpoint 1 Event * Parameter: event */ void USB_EndPoint1 (uint32_t event) { switch (event) { case USB_EVT_IN: GetInReport(); USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport)); break; } }
