Low Profile omni directional indoor celing mount antenna for GSM 900, 1800 and 2100
gamba007
Junior Member level 2
Johannesburg
Does anyone out there have any suggestion on the design of a low profile ceiling mount for LTE?
Antenna type etc. ( No higher than 40 mm and L x W < 100 x 100 mm^2)
Also the H plane pattern must be omni directional and across all bands.
Gain 0 - 3 dBi
All suggestions welcome
you can make a simple dual band monopole which should meet your specs.
(824-960MHz and 1710-2170MHz) --> Is this the frequency of operation ?
Let me start by saying an omni-directional antenna is a practical impossibility. Besides you only need to cover a hemisphere. So I agree with the other comment: use a monopole mounted over a small ground plane to get a wide coverage.
There are also ways of getting wide angle performance out of patch antennas if you are looking for something thinner than a few cm.
Hi sorry to crash into this thread. I am building a dual band quasi Yagi antenna to receive GSM 900 and 1800 frequency band. Is there a way to improve the s11 parameters through physical changes made in the design of the antenna?
